Custom/Hybrid Steve-uk 2 Day REV build
steve-uk
Manners cost nothing
Barrie - ontario
so after picking up my REV hull from surfersmurfs place in cleveland it was quick (6 hour) drive back... little bit of shut eye and over to Junkyardj's to get started
picture.php
First emptied out all the crap smuggled across the border :27:
then started fitting all the brackets
picture.php
next started stripping out the superjet guts
picture.php
and the pump
picture.php
motor on the bench prep'd for a junkyardj crank seal replacement
picture.php
steve-uk
Barrie - ontario
picture.php
crank exposed
guess what... these seals REALLY needed replacng ... thanks Junkyard you da man :kiss:
picture.php
whilst out fitted a umi coupler
picture.php
next came the pump, 148mm Mag pump
picture.php
steve-uk
Barrie - ontario
next steps.....
simple things left to do.. re-turf and add side rail extensions, the REV side rails are too small to stand on for hood tricks... hood seal needs replacing, water ingress withe the beat up on i have is insane
Then add the thrust innovations trim system won at wave daze
probably going to go with a worx freestyle dominator ride plate and pump stuffer, rides very nose up.. jumps very nose up (destroyed my carbon ride plate in VB)
Possibly changing the motor.... watch this space
BruceSki
Formerly Motoman25
Long Island
shortening the steering or pole would probably help the nose up...
that stock steering is long.
ski looks real good otherwise.
how does that mag pump work out with a mild 701 motor? and what prop are you running
steve-uk
Barrie - ontario
i have already shortened the pole by three inches since then.. doesnt ride so bad now in regards to the nose... but when you jump it wants to go vertical...
pump runs great,, had many people saying it was too big, my motor is pretty much stock with the normal bolt ons, head, b-pipe, enhancer, V force two reed, still running stock 38s
im running 8-15.5 prop
steve-uk
Barrie - ontario
yeah when i got the pump i got three props and that was the lowest pitch... hooks up beautifully, the combination withe th more bouyant back end of the REV hull means it pulls out of the water excellently too
i think adding the worx pump stuffer will make it better still
BruceSki
Formerly Motoman25
Long Island
I am running a worx 205 intake grate with stuffer attached and didn't notice much when i put it on. i also fixed a crappy pump shoe intstall i did at the same time though so i felt like i lost hookup if any, but I didn't have the brakes effect when letting off the throttle since the pump shoe wasn't hanging down anymore.
BruceSki
Formerly Motoman25
Long Island
I had a very very agressive blaster R&D intake grate on the ski before i switched to the 205.
im much happier now that i don't have the brakes effect, but i feel like i lost just a bit of hookup.
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
What can you say about current power of the ski? Wouldn't porting it be a wise decison? You pretty much have all the bolt ons...
What is the weight of your ski? (rEV)
snowxr
V watch your daughters V
Waterford, MI
thats concerning considering its supposed to be the best intake out there, i like the look of snowxr's grate too
Thanks! More and more people are using them with great results. I think it's time for a Christmas sale.
