Im hoping someone can give me a little insight.
06 Sxr, rrp pole
I can not adjust my steering enough to get my bars and steering nozzle straight.
Both adjusters, under the chin pad and next to the nozzle are screwed all the way in and will not screw on any further. With out being able to screw them in further my bars are off approx. 5 degrees in relation to my nozzle.
The only thing I can think to do. Is to cut the threaded part of the cable so the adjusters will screw further in. Has any one else had to do this?
am I missing something really stupid? I feel pretty retarded as I have messed with this on and off through out the winter. Now spring is here and I can not ride the ski the way it is.
I also have a ton a slack in my throttle cable, have my adjustments set as far as they can go but still need more to get it some what tight. I can pull my finger throttle in half way and still not rev the motor. The only adjusmtments I see are at the finger throttle and at the carb.
Im starting to mess with adjusting the pole length. But I cant see that I should need to.
06 Sxr, rrp pole
