- Albemarle NC
01 superjet recently installed msd inhancer / 2deg timing advance/ coffman sizzler pipe and lightened stock flywheel. Ran fine, started and stopped fine several times riding. The last 2 times I've rode, first time ran fine till I put it back on trailer. Went to start it to clear water out and I had nothing on start switch. Not even a clicking sound you get when the relay goes bad. It was just dead. But the battery is fine. After 15-20 times of trying start button it fired right up. The next time I took it out it started fine every time I tried it, but would not stop the engine with stop button. I pulled the kill switch and it took about 3-5 seconds for it to shut off. I started it back up and every time I go to stop it, it takes minimum of 3 times hitting the stop button for it to shut off. I have checked and cleaned the contacts a month prior to the above mentioned changes due to trouble shooting the relay going bad, (second relay in 2 years) Any thoughts??
