Other square nose pole bolt diameter
Pablo
sqeez bth levrs & lean bk
georgia
You guys know the diameter of the pole bolt. I've got to bore out an XFT pole bracket and want to run my single bolt, rather than two bolts, so I can use a pole spring. The catch is that the single bolt won't pass through with out boring. I'm gonna run by Northern on the way home and get the right drill bit to do it.
