- manchester TN
Came out of a running ski that I bought for the bottom end and carb set up. The cylinders measure 84.40mm with a caliper. comes with everything pictured. The guy I bought it from said the motor had around 10 hours on it since rebuild. shoot me a PM if you have any questions. also I was not able to do a compression test cause the flywheel cover had water in it and rusted everything inside.
