so will a 46 mikuni be much better than a single 44?
YAMA CAT
Catnip Junkie!
B'ham, AL
will a straight aftermarket mikuni have the right bolt spacing? I know the wetjet spacing is wider but I thought the regular aftermarket carb would have the same spacing as a 44. I guess I'll see, I just bought one.
My Black jack bolted right on to my stock manifold.
douglee25
m3booooy
South Jersey
A straight aftermarket Mikuni 46mm will bolt to a stock manifold. A wet jet 46mm has the wider spacing and therefore will not directly bolt up unless the holes are elongated.
Doug
Well guys I just upgraded my single 44 mikuni to a 46 black jack I bought from nikad. It seemed to improve for the moment I rode the ski. The boys just got through rejetting it and tweaking it for the second time. My husband took it for a test run and my driveshaft stripped out. :banghead: :banghead:
Once I replace the driveshaft I will let you know.
I went from a regular 44 to a blackjack 44 made a huge difference in responce and really crisp.Nice grab btw
