So, I'm getting a Lamey and . . .
waxhead said:
I have seen a rive like that to mile
I used to think it was only the r&d
but not long ago i saw a riva with the close together manifold as well
Most of the riva ones have correct 108 ?? mm spread
108 mm spread center to center?
waxhead
wannabe backflipper
gold coast
The manifolds where the carbs are closr together have a real nasty short side radius and it tend to throw the fuel to the out side
I have found that it tends to blow your ski up if you get any real hp out of it
In fact so much that i will not tune anyones ski with this manifold on
i didnt believe it until i changed manifold and saw the difference
Aaaahhh...gotcha. So, do I still need to run that plate with an aftermarket (Riva) manifold?
Tuscaloosa, AL
keefer said:
What is bad about the carbs being close together on the original R&D manifolds? I have been told that the dominator is much better, but I thought it was only because the setup allowed for the carbs to be removed alot easier. Whats the scoop?
They are talking about the standard R&D Manifold, not the Dominator/boysen style.....
