thanks madoyster,
you are right, the unwilling ness to spend my hard earned money has given me more than a few ideas, some good, some NOT so good.
:biggrin:
the bottoms sections that I cut off and reused are threaded.
I will get longer bolts, start from the bottom of the turnplate, go thru the threaded cradle, and they will stick thru far enough to act as studs, then a nut on top of the bar cap will clamp it down.
welding is likely not needed, but would be easy to do if I decide it needs to be stronger.
we discussed earlier why the bars need some type of cradle, without it the bolts are put in shear, and the design is to use them in tension.
among other reasons.
im sure it will all work though. hell a hose clamp and a 24" peice of of broom stick would work for a while!
