sn with rn pole
SkiDiggity
formerly kawirider142
quick question i am thinking that i may want to put the rn pole on my sn i mean i have the aluminum handle pole already but i have seen quiet a few sn's with the rn's pole can i get some feed back on it.
what is the difference and where do you get the bracket for the rn pole?
thanks,
Shane
Boris
The Good Old Days
You don't need a RN bracket. You can make the SN bracket work with some fender washers and a bit of clearancing.
The RN pole is much slimmer than that SN abortion and can be shortened with ease, is quite strong and relatively inexpensive.
Etheraldreamer
Be there and be square.
Spring Hill, FL
or you could just get a stock RN bracket and redrill holes. there are plenty of stocks as TONS of people replace them with beefier aftermarket units. only other thing you need to do is redrill and move your hood hooks. thats the route i took on my square.
or yes, washers work too. lol
Boris
The Good Old Days
If you like the length of your pole now why fak with it ?
Just ride unless you have too much cash.
Now, if you wanted to run a shorter pole than a RN pole might be the way to go.
FyrHazard
Ski Eat Sleep Repeat
Iowa
I really like the RN pole on my square. I needed to go much shorter than the stock SN pole and I think the steering plate angle is better too. Just feels better all around. I made a custom bracket to mount mine that allows for the stock hood hook location and uses a RN spring. I'm having a few more of them made if you're interested, but yeah it is possible with either of the brackets.
QuickMick
API 1104 AWS CWI
thanks,
Shane
I make a great bushing kit for the RN pole to SQ bracket if your interested. No fender washers needed.
Aluminum and Delrin bushings.
Etheraldreamer
Spring Hill, FL
id have to say if you already have an aluminum pole and are happy with the length stick with that. the RN pole while stronger than the stock glass SN pole will still break before the aluminum one.
Superjet112x
superjetaholic
Richland,Wa
or you can contact ski-innovations.com they make a conversion bracket
cookerq62
Life's Been Good
Upper Bucks, PA
The conversion is well worth it IMO just don't use a RN bracket. Do the washer thing or get the conversion bracket. With a RN bracket you have to relocate the hood hooks. Also with a stock RN bracket the pole won't go all the way up. SN poles are so freaking ugly, heavy, and long. It completely changes the ski for the better both looks and handling.
CoreyLKN
LKN Freestyle Militia
Lake norman, nc
Just do it! Order the conversion bracket and get a RN pole. I went from a stock SN pole to a -6 setup and it was the best thing ever! Just do it you wont regret it!
FyrHazard
Iowa
I think I paid around 100 bucks for my pole, and my bracket would be around 150. Not sure how much ski innovations is charging for theirs. But it's still a relatively cheap mod.
attachment.php
attachment.php
