Freestyle SN SuperJet Winter Re-Build
Holy Crap the water is cold even with a wetsuit on...
I finished up and took it for a test drive. I need to tune the bottom end in better though its really dragging butt. You can probably see from the videos I'm not getting much air at all. I think to much water is getting to my waterbox or maybe my headpipe screws are clogged. I'm kinda at a loss what the hold up is considering everything i put in the ski. Any one got any ideas?
Solved the bottom end problem.
Thanks to Dustin/Duncan for helping me sort out my issue and giving me some fuel line to test with. I was using those crappy colored fuel lines that were too big. The pulse line on my carb didn't have a vacuum seal. I ended up ordering some of the 3/16 fuel line from mcmastercarr and even though it was harder to get the lines on I think it will be worth it in the end. I also added some extra shock padding to my hood because my UMI angled throttle lever kept hitting the hood and could get stuck in the throttle open position.
Here are some crappy cell phone pics of the ski all done.
