Hello all, I am hoping that some of you might be able to to help me figure out what's going on with my Superjet.
Some background; My brother and I have nearly identical superjets, squarenoses with 701s, both have new hooker 9/15, both have completely stock 701s. I recently did the pump bearings, wear ring, intake grate (worx 201), prop, mid shaft bearings, motor mounts, and starter. So theoretically the driveline is perfect on my ski. I aligned it well (better than my brothers). and the compression on my ski is great (148-150psi). However, the ski is simply not as fast or explosive as my brothers ski. its close, but not there on acceleration or top speed. My ski also makes this whirring kind of sound from the mid shaft area, I originally thought it was weird cavitation, so I did an intake grate and it didn't really change at all. I am confused as to what this sound could be seeing as how all the driveline bearings are new and aligned. I would also like to note that the carbs should both be stock (jetting), I was worried about the high and low needle tuning but I honestly don't really know how to tune the needles properly without blowing them up. the screws are not out of spec at all. Curious to see what you guys think!! both skis have also had the coils, and batteries replaced. I have attached a pic of the plugs out of my ski. Thanks guys!
