nucleus_coolins
Does things to makes the do goods
- Bay Area, California
Ok i really wanted to share a tale of tittys and beer but you guys will have to settle for another Square Nose build.
The idea for this build started with a spare motor, an oem 144 pump i had leftover from my fr2 and a crusty SN hull taking up space in my friends yard.
I started accumulating parts from various members here on the X, all successful transactions and i couldnt be happier with all the parts i picked up.
Also swooped up a bunch of lightly used parts from my good bud that lives around the corner.
Heres a shot of the hull right after bringin it home
It had been sitting under a literal pile of poo since 2011.
This pic was taken right after hosing off most the manure stains.
Got rid of that oem pole and bracket with the quickness - Aint nobody got time for that.
You can see the nose had been chopped, it was pretty solid too. Coulda run it as is no problem, but what fun is that? And what kind of titty would it have attracted? (Mostly man titty probably)
Man tiddy magnet right there
I feel like i should put gifs in here. All good threads have gif right?
My buddy did a ton of work to this thing, he cut the whole tray out in 1 piece, defoamed all the soggy-sog, reinforced the inside tray cavity, built up and reinforced the tray chunk he cut out and buttoned it back up with 3 footholds! 3 dude!
He didnt put any foam in it tho, pretty sketch sauce.
He also gave me a heads up the tray took on a ton of water every time he had it out so i got straight to tracking those leaks down.
Pumped some air into the drain plugs and the whole tray just foamed like a spent keg. Pic above is only a tiny taste of the pain i endured for probably a whole month tracking down all the pinholes.
Dude build threads are hard, idk how u guys make these things look so easy. So much typing, my phone hates me right now 12% batt
To be continued when i get off this train and get some beers going
Brb
Brb
