Super Jet SN Pole conversion bracket
Trimmed RN pole/SN bracket works great if you have hood straps..
SN pole prop rod also works if lengthened about 1/2"
I'm using a blowsion spring
Tis the method I used.
I can post pics of mine if you want...
Why wont the lowered RN bracket we sell work? I dont have a SN to test fit it on.
$75 shipped and if you cant make it work Ill take it back
'kotajoe
Do Good Crew!!!!!!
NRH, TX
The mounting angle is different and wont allow the pole to fully extend. The stock sn bracket can be grinded down and modified to work but you cant run the hood hooks in the stock spot and doesnt line the pole up evenly with the rest of the body work.
I am currently running a ground down SN bracket and RN pole that I bought from an X member. It works and still has the hood hooks but if I ever break the pole and buy an aftermarket pole I don't wanna have to grind it down too
Thanks for the input
'kotajoe
Do Good Crew!!!!!!
NRH, TX
Anyone have a pic? I'm still not understanding the not fuly ext.
Instead of the pole coming up to an almost 90* angle to clear the hood for removal, the pole only opens up to say 30*. It takes serious grinding and metal removal from both the bracket and the pole in order to open up enough. I suppose an aftermarket pole bracket will work if you modify the mounting surface on the hull.
No one wants to try to use our bracket? After looking at the brackets I still think our RN bracket will work on a SN with a RN pole. But I don't have a ski to try it on.
rwilliamtaylor
Ride, Wrench, Repeat
San diego
Here's a pic. I think the problem is getting the handle pole to sit low enough and also clear the very front/bottom of the pole and the hull when in the fully up position. I have a pole limiter on mine anyway so I don't seem to have any problems. I'm not sure which bracket I'm using either since I bought the ski with the handlepole already done this way.
Well I can always change that before we weld them. I just need to know how much it needs to be set one way or the other. But from looking at it I still think it will work the way it is.
'kotajoe
Do Good Crew!!!!!!
NRH, TX
The white ski above looks like it has an Xmetal bracket on it. As for the Rad Dudes bracket I would be happy to try it for you and let you know what modifications are needed after a test fit. Shoot me a PM
