Super Jet SN 61x budget swap.
Well, ive acquired enough parts to do a 701 swap on the old ladies Square nose. I have a few questions though.
I will be running:
-wetjet 61x w/ yam 650 head. (180 psi)
-Wetjet intake and 46mm mikuni.
-PSI pipe
-Debating on an OEM cdi or Riva.
-Oem pump with 9/15 hooker.
My questions are:
-Will this setup be efficient enough for a 9/15 or should i go higher?
-What should my carb be set at? Its currently setup for wetjet specs. I left my notes at home..
tor*p*do
Squarenose FTW
NW NC
First, check the squish before running a 650 head on a 701.
9/15 should be fine.
I run my 61x with a 46 at 120 lo, 150 hi, 2.5 N&S and black 80 gr spring
Quinc
Buy a Superjet
California
That is about where I would start too. Might Also try a 95g or 115g spring to see if it helps throttle response.
