Skywalker's project X-Jet revamp
F
Freestyleriverrat
Guest
How is the engine assembly comming along? Has the crank been sitting in oil since she broke the surface?
Thanks a bunch. Oh, Superramjet has a TLR ported and decked flat top setup for the 66e that I am gonna run. He has always wondered what it would run like, so I guess we'll see. The crank still looks great!!
Luke
DaUpJetSkier
I like square
Marquette, MI
a lil OT, I know that crank was sitting in the water all the time but is there anything besides just coating crank is oil you should do for storing a regular one.
Lakeman
Stand Up All The Way
Wichita, KS
Luke, nice paint job. I noticed your water pissers up front on your ski. I had to move mine because the pipe that Jeff builds now will be in the way. I think you said you were getting a new pipe and if so your current location will be a problem.
Dale
Well.. The motor is built, pole and steering is in, pump is in, throttle is ready, battery in,""BILGE IN"", sooooo close!!!!! Gas tank and sealed manifold should show up any day, can't wait. Then I go ridin' I bet there is only like a couple hours of work left to do. Yessssss
Here are some new pictures, kinda like the last ones but the pole is on. What do you think of the exhaust outlet I made, just curious??
I think the latest and greatest. I was using the old pipe, which worked good I thought, but, Jeff is replacing it with the new one. It will be like the one superramjet has.
See ya,
Luke
