My orange ski started pulling some major stunts with me this weekend. It bogged down really bad and then wouldnt start again(the first time). I got a tow back to shore, and took off the hood to find the whole inside of the hood was really hot. I took out the spark plugs and they were almost too hot to touch. The whole engine compartment was steaming. The tops of the spark plugs were somewhat white. I figured I had mixed up the fuel a bit too lean so I added a couple ounces of oil to the in tank mix. The fuel did look a bit too light colored before that. I also changed the spark plugs. 30 minutes later... the same thing happened.
Throughout the weekend the same thing happened 5-6 more times. For the rest of the time I know it wasnt lean mixed fuel. I dont konw where to start as far as troubleshooting this issue. Only engine mods on this ski are a milled head and B-pipe. I went through probably 16 spark plugs on that ski this weekend because the ski would start with a fresh set of plugs each time that werent hot. Come to find out, when the ski cooled down it would start with the ones that were already in it when they had cooled down.
