problem need some solution
I had an overheating on 701 engine, 81.5 piston , factory B pipe dual cooling system , TDR water box , and ADA head
the problem started after 1hr riding and the cooling system was ok , once the engine got overheating I switched off
and now the pressure on the rear piston is 0 ,front is 150 PSI
oil mixing was ok ,the engine was working good before one day
IDK why the engine heated , if someone can clarify to me the specific reason
