Single Line B Pipe Routing
B-Roy
Makin' a Comeback!
MICHIGAN
How much of a difference would it make if I switched this up. I went according to Factory Reccomended Specs, and everyone else I know is running it different. Whats the best way to run it using single cooling?
And how much power do you think I will Gain, and where will I gain it if I do switch it up?
Im running from the Pump to the manifold. Head to top of the Headpipe, bottom of the head pipe to the T, Stinger to the T, than the T to the pisser.
:biggthumpup:
Waste Land
Non Multa Sed Multum
Florence, AL
No gains....just a better cooling route.
Pump - Manifold - Head to Bottom of head pipe - top of the head pipe to T - Pisser/waterbox.
The straight part of the T should go to the pisser and the "T" off should go to the waterbox
3/8" fuel line from autozone works fine as cooling line too
jetskiking
Im done sanding!!!
Dallas Georgia
There could be a hundred pages on how to route a B pipe. I run mine almost the same as yours except I use a flowvalve to dry up the waterbox on the bottom and I dump a restrictor bypass off the front of my head.
