Blaster sidemount bog??
fl
heres my problem. it only started this seasion when i installed a bpipe ltd. if i fall in the surf and go to sidemount all i get is a brrr brrr like its just bogging out.this happens 90% of the time.what would cause that..the carbs getting flooded??? but if i wait a few seconds it starts and is fine...
fl
it stays pretty dry with my rule 500 and versiplug.. if i unhook the pump before i sidemount it revs fine. only when it hooks up its just brrrr brrr. then if i wait a good 10sec it will let me sidemount lol wtf
RoscoeJ
760 B1
NJ/PA
Do you ride with a water sock on carb? do you have stock carb and intake? How often do you replace plugs?
fl
stock duel 38s,stock f/a,new plugs. i think the problem is if i fall and lean it over too much while its still running (idling) it gets flooded with gas.im pretty sure thats what it is because i can smell the gas fumes.
Idaho
I had the same problem on my SXR. It was all due to carb tuning. I thought it was my low jet but it was tuned good. I ended up going from a 2.0 N/S to a 1.8N/S with a stiffer spring. I bumped up my low jet and now the carb side bog is gone!!
Tyler Zane
Open Your Eyes
i had a bogging issue that only happened after i landed from a big jump. turning the low speed screws in 1/8th of a turn fixed it and i didnt notice any changes in normal riding conditions.
