- Reno,NV
I glued my pump several times and it came loose every time, anyone made an easy braket for duals/singles or converted existing brakets, show me your ideas...
Thank you
Thank you
youre either using the wrong glue or not prepping correctly....
I have used silicone, jbweld, superglue, epoxy resin and once a piece of chewing gum and none have ever failed
sand with some 80 grit, clean with acetone and you should be good to go
my roommate screwed his down and cut the rest of the screw off ts not going anywhere
id say some waterproof epoxy resin
never done me wrong
Mine is currently tie-wraped to the gas tank ancor braket.
But 5200 as worked well in the past for me.
