300/440/550 Show Us The Sexiest X2s
onesojourner
I use a thumb throttle.
springfield, mo
are the 750 bpipes as effective as on the kawi as they are on the 701? what is the advantage of using the superjet chamber over the 750 chamber?
and are the 750 bpipes as hard to come by?
Legdragger
Bringing it back
New Hampshire
waxhead said:
nah its a superjet pipe
I originally had a Factory pipe 650 wet pipe then realized it was the same as the pipe I had on my SJ. So I found a limited chamber for a SJ and swapped it for the old 650 kawi chamber. I think it is a good combination for the big bore kawi motor. It is all about the low rpm BRAAP! I have herd the wetpipe for the Yamaha and kawi are alomost the same thing. I like the Yamaha's lower center of gravity compared to the Kawi "mod pipe" design.
groaty
X2 JUNKIE!!!!
new hampshire
here is the x2 i've been working on over the winter.
i'm waiting on turf, pissers, and an exhaust manifold gasket.
D
Dski
Guest
heres my rattle can painted X2.. hopefully it will hold up through the summer.
groaty
X2 JUNKIE!!!!
new hampshire
did you clear it? and from my own experience if you do any kind of jumping i would get the lock setup for your fuel door. i lost a few of them that didn't have them. nice ski by the way whats it have for motor mods? if any....
D
Dski
Guest
no clear. the white appliance epoxy paint has pretty good gloss to it as long as you give it a 2 or 3 coats. the stainless steel is non-gloss(dont recommend it, i just used it because i bought it). the engine in bone stock. it was sitting in someones yard for about 5 years when i picked it up this winter. so im just gonna ride it this summer and see how i might want to mod it next winter. the gas filler cover is probably gonna get replaced by one with a latch when i find one.
WaHoo_1
Surf Swimmer
Tampa, FL
Here's the one I did last year. Came out great and now it belongs to a friend living in Arkansas. Turns out after all that work I'm really more of a superjet person.
Charles
that was a nice x-2. Crammit did some sweet work on her. :hail: I recall a while ago when it was for sale.
