- pasadena MD
should i get a sheet of hydro turf or a hydro turf kit for my ski?
everyones not as talented as others when turfing. its easy for me but i know what im doing.People stress out too much over turf. Get a sheet. For the bottom, make a template. I never make templates for the sides. Do them first. Just cut a piece big enough to cover the area you're trying to turf, then trim away the excess. Use alot of heat and wrap the turf inside the hold as far as you can get it. Then cut smaller pieces to fill in the gaps.
Just take your time, do some basic measurments, give the glue time to set before you stick it down, use alot of heat, and turf is nothing to worry about. I think the skis that are done with sheets end up looking much better than the kits.
