When sealing the bottom end, do you put sealant on both cases or just one?
Ben34 Location Pa May 18, 2022 #1 When sealing the bottom end, do you put sealant on both cases or just one?
fastgtfairlane Location Charlotte, NC May 18, 2022 #2 1 side is enough. Just a thin coating. Wipe the access
DylanS Gorilla Smasher Location Lebanon Pa May 18, 2022 #3 Ben34 said: When sealing the bottom end, do you put sealant on both cases or just one? Click to expand... I do a thin layer on both sides personally, jusr use my finger to spread it
Big Kahuna Administrator Location Tuscaloosa, AL May 18, 2022 #4 1 side can be enough if enough sealant is used. Both sides helps to guarantee it.
