Vumad
Super Hero, with a cape!
- St. Pete, FL
Anyone use Seafoam additive? I have a buddy that swears by the stuff you spray into the carb when the ski is running. However, he's not well versed in how motors work. The Seafoam that you spray into the carb only cleans up carbon build up, it does not address carburation issues. Seafoam does have a fuel additive that is suppose to liquefy varnish and other build up and resolve issues due to water in the tank from condensation build up.
I bought my fiance a GP1200 2 weeks ago. I've had it out 3 times. Got the steering issues resolved and it was running great for the most part. It started right up with primer cold. It didn't like to start warm. Otherwise it ran perfect. The 3rd time out we tried to use it to wake skate. It had a very slight hesitation from idle if WOT, but a slight ease into the throttle it would pull hard off the line. It ran great the whole time other than the slight starting issue. After a few sessions, we parked the 1200 while I rode my SJ. After about 2 hours, I went to ride the 1200 before I loaded up (still testing and looking for issues). The ski wasn't running right. It felt like it was loading up. About 5 seconds of bog, then it would pull hard out of the hole and all the way to the top. Idling again, it would bogg, then pull hard.
I replaced the plugs but haven't taken it to the lake again to test. I do not think it has anything to do with the plugs, they had a nice brown color. I am just starting with plugs because it is easiest and who knows when they were last changed.
Assuming the plugs was not the problem (and certainly isn't the cause of the hard starting), I am going to need to work the carbs. The ski was running great, so I'm not in a rush to buy a rebuild kit or invest time in working on the carbs. I know seafoam spray wont do what I need. I don't know anyone that has used the additive. I am concerned that adding it to the tank might break up a lot of build up and make the problem worse. I was thinking about adding 2oz to a 1ga can (still oil injected) and sticking the fuel intake into the gas can.
Anyway, anyone have any feedback or opinions on the product (or similar) and the situation I am talking about. Normally I address my carburation products by manually cleaning the carbs. This isn't my quad. 3 carbs is a lot bigger job and more expensive. The ski was also running so well and it's likely to be a very minor problem since it changed so suddenly. I'm sure it's nothing to do with the motor or electronics.
