Started mocking up the drive train on this yesterday.
When I bought the hull, the pump inserts were in, pump shoe mounted, Bulk head in, midshaft inserts in & motor mount plates in.
I'll start with the bulk head. Is this supposed to be square to the top of the bond rail? This one is tilted towards the back of the ski slightly. I'm having alignment issues between the driveshaft & midshaft. For starters, the midshaft was mounted about 3/16" off center towards the starboard side of the ski so I've pulled those inserts already and will have to relocate them. Driveshaft location looks good in respect to being centered side-to-side. However, there is about a 1.5mm gap on the top of the midshaft/bulkhead when aligned to the driveshaft. This is what concerns me the most.
I mocked up a set of cases with the midshaft mounted in it's current location and was able to get everything aligned fairly easily. I think I will have enough side-to-side adjustment in the motor to be OK after the midshaft is relacated and centered.
Pump:
When I pulled this pump out of my 07 hull, I had to use a stack of shim on the rear to get the shaft centered. I'd say close to 4mm on the rear tabs. I put the pump in this hull and it's the same way, about 3.5mm or shimming on the rear. I transferred the reduction nozzle over to the skat mag I just picked up and it's the same way. The mag had a NEW wear ring section too so that eliminates the pump/wear ring IMO. Could the Raider reduction nozzle I'm running just be off that far compared to a stock SJ reduction nozzle? Even if I bolt the pump in tight with just the first 2 mounts, there is still about a 3mm gap between the rear tabs and hull. Pump seal seems square with the pump shoe.
I took a couple picks of the shim stacks I had to use in the 07 SJ hull.
So I guess my main question is getting your opinions on how I should address the squareness issue of the drive shaft to bulk head & midshaft. Side to side is right on the money, top and bottom are off. Can you shim the midshaft? And how about the pump + assload for shims issue? Maybe I should look for another reduction nozzle to try too?
Thanks guys
