SBT... Sad But True
Status
Not open for further replies.
If the center pin's weld is not broken, it is set in the phase as it was built. As for whether it was in phase when built by SBT, if they use the apparatus in their US patent 6363609 (Method and Apparatus for Aligning Crankshaft Sections), it has not choice but to be in the same phase as the jig. Among other things, excessive compression or inadequate squish band will also disintegrate a thrust washer. Also, don't confuse "trued" with "phase", they are two entirely different subjects to someone that knows cranks
Status
