Funny thing is, my small motor with large carbs uses less fuel than a stock SJ.
Do big carbs always equal to higher fuel burn numbers ??
maybe because you are not having to open the throttle as much to make the same power as a stock SJ where you probably would ride around with more throttle being used.
Why not just take a nicely ported 701 with OEM 38's and be done with it. I dont get it. You build up a big motor, you run fancy ignition and you want to put on smaller carbs to try and save gas. Stick some 38's on there, and jet the carbs for your application.
bk, I dont think I will use near as much fuel with the 38s only because the total flow will be cut down significantly,less flow = less gas used. I guess we will see as I have never tried anything like this before,it is a rarity to do this kinda thing since this ride zone is so jacked up I have no choice.
Id like to see that conversion plate,can you post a pic here or email it to 1supra@cox.net. Its possible it might work for this kinda mount
Gordon, I run through the slow wake a little faster than most,lol not ridiculous but with the nose slightly out of the water,not sure what rpm,but it sucks major fuel,its about a 15 to 20 min deal depending on speed,I check the gas used before and after it and its always at least as much as I would have used freeriding in the ocean for the same amount of time. I also dont run wot down to the spot in open water,maybe like 20 mph,its such a PITA to try and ride right below the pipe with big carbs also,when you are just trying to get somewhere,major fuel is being used here as well.
For off the beach rides id be fine with 1hr to 1hr 15 usage for the extra power it makes.
ocd,Im just not trying to deal with pulling anything out or riding with gas in the tray,there has got to be another answer thats less PITA
cool thanks,in freeride if you think about it most of us are giving it wot blips,I know I never stop my pull,everything I do is throttled complete in blips,so it should be the same thing with 38s just not making as much power
You and scorn arent much on reading huh? Ive said at least twice in this thread,I have a 2 part boyesen mani and a few top plates,Im going to try some 38s on one for this ride area that is way out a slow wake and a ways down in open water. This way its a 5 min switch back to 48s anywhere else if I choose. I will deff still be making more power with this stroker motor on 38s than any pump fuel ported 701 would
fx,good to know bro,I bet that 865 pv is super linear and torquey with those 38s,what kinda ride time you getting out of them
ocd,thats why im not taperboreing the 38s,I dont want to flow like 44s,kinda defeats the point here.Im not doing it cause I dont have large carbs to run. what kinda run times you getting on 865 and 46s. I need 2 hours+ in this spot
