schicks
Karma Enforcer
- West Michigan
so I went to start my SJ on the trailer before putting it in the water (trailered it further than normal and I turned the fuel selector off when I normally leave it on), and put probably 4-5 shots of primer which is more than what I normally shoot in. The ski ran away and rev'd out of control, luckily I was able to get it to die after only a couple seconds of reving out. I rebuilt my motor last fall, new gaskets, pistons, rings, seals, all OEM etc and did several leak down tests to confirm that I did not have an air leak (had a leaky base gasket last year). My question is: can giving it to much primer and having a little extra air in the gas line cause the motor to runaway? Or do I have another air leak? I started it up on the trailer again after that and it seemed fine. When you do have an air leak, does the motor runaway every time, or does it happen sometimes but not all the time (out of the water)?
