Plastic, our torture test to failure was 15% stronger than the OEM nozzle in the identical test. (Yes, OEM nozzles were harmed during this testing!)What are they made out of?
62T Nozzle will be available to order within the next two days. Then we'll move on to Krash, 155mm oem, sxr800When is the trim version coming out?![]()
Yes. keeps the nose down.Noob question, but what is the purpose of the -2 degree nozzle? Better cornering? Less porpoising?
Because they are the worse dealers ever. Gave us a taste of the awesome product and then took it away!
On a side note my nozzle is still holding up great after a lot of abuse and my kids continuing to use it as step..
Any reason you guys aren't selling the nozzles and just the STL file?
I have a Markeforge and printing this nozzle with Onyx material is $50. It's nylon based, which I believe will not do so well in water.
