- Lake Orion, Michigan
Roo, are you certain that you don't have a vibration under the hood that just transmits through the ski and feels like the driveline? It would make sense that it only did it under load.
I did use regular silicone to smooth over the joint between the pump shoe and pump.
99.9% sure it is coming from the firewall/bulkhead and back.
most noticeable when on a AC Racing beach stand in the water - you can really hear it towards the rear of the ski.
ever sucked up a rock in your pump and listened to it play ping pong? that is the best analogy i can give, but minus the rock
i have a new midshaft/housing and motor mounts i will be installing when everything goes back together... fingers crossed.
silicone... basic RTV?
my motor and midshaft line up perfectly btw - slides together with no effort.
