a friend of mine bought an '07 SJ, from riva, that came with a PMC cylinder and head.
i noticed the side of the cylinder was always oily. we'd spray it down w/ brake cleaner, he'd take it for a quick ride, come back and it was all oily again. we searched all over looking for leaky base gaskets, but the oil wouldnt travel up anyway so i told him to take it back to riva because the cylinder obviously has a crack in it somewhere in the ports.
he took it there, they took the engine out and apart and said that the cylinder was fine. i said "no, its cracked. let me see the cylinder. i know almost exactly where it was coming from. ill bet i find a flaw".
i went back to the service area and in about 3 seconds, i spotted a casting flaw. there was a hole in the boost port.... not a crack... a HOLE in the casting. you couldnt see light through it, but if you poured alcohol into the port, the outside of the casting would become moist.
so riva welded it, instead of replacing it.... even though they never told him it had a pmc cylinder when he bought it. they even tried to tell me, over the phone, that it was OEM. i asked them why it has "PMC America" cast into the side of the cylinder and why the head has no torque values like ALL yami heads do..... no real answer
his ski is still running, but id rather run a used oem than a new PMC.
