yes turn to the right brings RPM limit up. Turn all the way to H which is about 9000 (not 100%) then turn back about 2 lines this will give you a good base to start. Run it and put a tac and see what you are at. Then adjust from there. ME i just turn them all the way up and get all limit as high as possible knowing it will rev out when it un hooks. Pat
I have the protec version of that, you can crank them up all the way but really no need. Mine is backed off a tad and still revs plenty high, kinda nice when you pin it off a wave, you will hear it bouncing like stock only way higher.
