I haven't been down to Fiesta Island since the Monday prior to Thanksgiving. With the rain draining topsoil, I wouldn't be surprised by the smell.Same here, skat big hub. Have you been riding down at Fester lately? I run down there and it smells like a toilet bowl..
Maybe I missed this but did you end up sending your Blaster mid shaft off to RadDudes to be re sized or did you use a GP760 mid shaft?
If the latter what year GP760 did you use or do they all work without any modification?
That 93 octane is going to be a bitch to get here in CA. There is a a gas station nearby in Uberrichville Rancho Santa Fe, which sells 100 octane. I could mix with premium 91 to get 93. But then again I like to whole pump gas thing.
Im at 3 degree advance now with temp sensor. I wonder if i disconnect the temp sensor and put the timing advance plate on for 6 degree advance I could get away with 91 octane? The 9 degree advance total pushes me to 93 octane
I read somewhere that the temp sensor bypass only advances it up to 3000rpms or so?
Thanks. Figure if I'm going to do this might as well do it right. GP760 it is.
BTW Thanks for the detail build. REALLY a makes it easy for anyone hesitant to do this mod to see exactly what's required to build a NICE conversion.
I'm currently in the process of another build like back in my gpr days and the stxr as well.
I have found that any build will always be slightly different when it comes to custom stuff. Hull years...redesign of aftermarket products....as in plates and so on.
I found some people have had no problems dropping in a kawi 1100 on a rad dudes plate using a gp 760 and some needed to ether modify the plate or the shaft. I have seen 3 different versions of the rad dudes plates. At least where the plate has different cut outs. Have no idea if they changed the angle length or anything else.
With my setup which I'm getting close to finish I had to modify the gp760 shaft as I could not get the bolts in for the engine mounts. I was about a 1/4 inch off. So I needed it milled down and added some threads to allow it to move back a little more.
It not hard to press the shaft out and have it spun and press it in again. Just remember to put it back to spec.
What's hard is finding a guy to spin metric threads I guess. I know a couple people around here who are killer at machine work and he did it No problem.
So sometimes each one needs it's own tweek.
All in all the blaster build with a kawi drop is not bad. I would assume the yam 1200 is almost a no brainer.
.That's awesome to hear. A lot of people helped me get my project done, so this is basically a collective effort from many experts. It makes my day when I hear you guys are using it as a key piece for your builds.I've read over this thread countless times. Thanks for posting up this build with the informative details and pictures. I'm in the process of the same build, so I'll have to post my build up also!!!
