Freestyle Rhass motor mount
denmark
I just instald 4 new rhass mount`s have not got on the water yet, it seemes too bee some vibration in the handle pole ? Is this nornale with new rhass mounts ? Is ther some break in perioede ?
rubbertoe
X-H20 certified
San Diego
Probably way stiffer than stock ,might be where your vibration coming from.i have never ran these personally but have heard the aftermarkets are stiffer.
Aftermarket mounts are indeed stiffer and thus transmit more vibration than stock mounts. They are stronger than stock mounts, and this is the downside of that strength. On the upside, this vibration does lessen over time and may even go away completely.
Fla
I think they are as soft as oem and not near as stiff as Monkey grips. They seem to have a little vibration if you have your idle set really low other that that while riding the ski they feel great I am also running the Rhaas midshaft and loving it
denmark
Okay Sounds like i need too put some ride time on Them. After reading the rhass thread seems mark gomez and zack bright hade same vibration att first
the motor mounts will break in over time and absorb more vibration. when they are new they have more reboundn in the urethane compound than stock, this causes the vibrations. over time the rebound will lessen and the vibration dampening will return to almost stock feel.
Awsome conversion kit as well for the js hull to a 701. perfect alignment. Vibrates a little as well in lower rpm range, but have a ported motor that may contribute to that as well. No vibration wide open throttle. Can't wait for the Kawi hull bearing seal carrier to be finished. Robin is great to talk to as well, will answer ALL your questions.
stagesrt4
see ya out there
St Charles IL
yeah youll notice a lil more vibration over stock...
I love my Rhass mounts...just one less part to have to worry about breaking...
