Rhaas lowered mounts for 1200 build
I have a set here , in all honestly they don't seem to be anything that special , they look like they are the same height as Superjet engine mounts to me .
I am thinking $200 shipped , I was going to use them in my Superjet build but I have decided to use OEM couch mounts instead on this one .
If you will notice when they run the couch mounts in a Superjet they have to be slotted or the stock bedplates machined down to fit properly because the Superjet mounts are shorter , although some people seem to get by doing neither.
I decided not to use them on my Blaster ll build and go with the ADA setup instead , mine is a very non typical setup using a Blaster driveshaft and a modified 1100 midshaft and ZXI couplers so the ADA setup installed backwards lines up perfectly and sets the engine back in the hull as far as it will possibly go. , it's set up for rec riding and wave jumping .
These are brand new mounts and they have never been run but I did bolt them into my hull just to take a look at how they fit in there .
This is the set I have , that's on my 650SX fixie , which pretty much everyone here probably knows is my ski .
Typically the way this usually works when you put up a WTB thread is you say yes I want them or sorry I am not interested
