When you say soneone has same setup as you.
If you have same hull with same engine venting in the hull then you should be able to use same jetting he has. You say you like it why not try it
But without knowing your porting and prop specs.
Most people don't realize if you have even a slightly larger prop you need more jet
But I like to start with 120-125 lows and 135 high jets and run the motor with stock carbs and figure out where my my screws are and then fine tune the jetting from there.
I always want my low speed screws at 1 turn, because there really designed to control idle fuel.
So if you have to big of a low speed jet you end up with low speed screws to far closed and that greatly increases lean run away risks. If your low speed screws are less then 1 turn its not if. But when will you have a lean runaway.
High speed screws I like at 3/4 to 1 turn.
This way you have more controlled fuel in a jet and still just little fine tuning room with the screws
Once u get the high speed screws past 1-1/4 they have to much wiggle room and jetting is inconsistent
In a race boat I like my high speed screws 0-1/2 out. Has best fuel control and rider can't lean boat down to hurt it
. But room to Richen if you should get a cool day or water condition.
But on a refined tune free ride boat I want high speed at 1/2 turn. Good control and room to adjust. If I need more then 1/2 turn adjustment something is wrong with motor and needs attention
Keep in mind it takes time to get your jetting that fine tuned.
But anyone can do it if you spend the time bracketing.
Example.
125 low. 135 high.
5 seconds of idle stab throttle.
Gurgles then pulls clean. Tells me I'm not far off. If idles 5 seconds and gurgles never pulls clean. I know I'm outside tunable range with those jets.
If idle then bogs, Richen both low and high. Remember. Just because your boat not moving doesn't mean your only in low speed jetting, jetting is throttle dependent more so then boat speed or engine rpm.
Look at a engine lean runaway. It's turning 7,000 rpm plus with throttle closed. Pure low speed jetting problem.
So if I have a bad bog I will first listen to the sound of my idle. Am a little lazy feeling and yang yang sounding. Or is it little gu gu crackle sounding. If ts crackle and girgly idle I know I'm Ritch on bot and the lean big is from lean high speed circuit. So clean up idle with low speed screw and get strong idle. Now lean bog is really bad. Open high speed screw 2.5 turns out. How's the bog now.
Better but still big bog, I know I need to go up at least 5 Five being 125 to 130.
Now out the high speed screw back to one increase main jet back to same test.
Once I get that all sorted out now I do a roll on roll off on plane run.
If the boat sounds lean when your letting off slow your high speed jet to small. Go bigger again.
Now it won't pull clean right away.
Now address fuel delivery with needle and seat and pop off.
Hope that helps
