Vumad
Super Hero, with a cape!
- St. Pete, FL
I bought a used b1 project and one of the drain plugs is missing. I have an assembly from a gp1200. It uses an 8mm lock nut, a screw and washers. How do i install this? Whats the trick?
Or get a versaplug and stick it in your drain plug hole...
http://www.shop.pwcdoctor.com/Versi...a-Polaris-Yamaha-04-on-NOT-GPR-BLACK-1401.htm
Waveblaster drain plugs just get screwed in from the outside...not sure if the GP drain is same as a blaster but if the holes line up ditch the hardware u got from the GP and just use some screws
Pictures would help us help you.
