Reliability question
munki63
Epoxy is my duct tape
Canada
So this year is the first year im modding my jet ski and all my friends are telling me im going to be wrenching all summer because of what im doing, but i dont think im going over board what do you guys think, here is a list of what im doing
Tubbies
Quick Steer with 0 Deg bar
REV Foot holds
9/15 Hooker Impeller
Ported 701
37cc Shark Fab Head
Mod Factory B Pipe
VForce Delta 3 Reeds
(edit)MSD enhancer
White Hydro Turf
Reed Spacer
201 Worx Intake Grate
I'm still looking in to my carb set-up
Thanks
That's the basic set up that everyone has on this site
I don't think mild porting takes little if any longevity away. People have been running that set up for years with no porblems, just maintain it
Make sure your parts are in good condition.
Do not use questionable parts.
Use new gaskets.
Take your time assembling everything.
OCD Solutions
Rentz, GA
FWIW. I got 7 yrs of rec riding out of a 701 that was build up for closed course racing and I have no idea how many hours were on the ski when I bought it. Over the years that ski proved to be the most modded and one of the lowest maintenance skis in my fleet. Still is actually
McDog
Other Administrator
Staff member
South Florida
Good luck with your new hobby/addiction. Once you start modding it snowballs pretty fast.
junkyardj
┌∩┐(◣_◢)┌∩┐
i dont think you'll have any problems with that setup..mcdog is right your hooked now lol! and when your friends ride your ski they'll be hooked too!
Frosty
New York Crew
Western New York
who did, or is doing, the port work on your cylinder? Mild port or race porting? What kind of compresion is the 37cc domes in the Shark Fab head rated at? Depending on the port work you may even consider going to 35cc domes...
junkyardj
┌∩┐(◣_◢)┌∩┐
once you start modding you cant stop, not sure why?? before you know it you'll be poor like the rest of us ;) whats the riding like in alberta? what are you building you ski for?
munki63
Canada
The lake I usally go to us 35 feet deep so It gets up to about 20, I mainly want to set it up for freestyle, but most of my buddys race so ill be doing that too, how are the great lakes
Frosty
New York Crew
Western New York
also, once you add a pipe (plus the higher compresion etc) you will be hitting the rev limiter. You will want to either send your stock CDI to pro-tec to be modded or go with an after market CDI (MSD enhancer). otherwise you will be turn more RMPs than the rev limiter will allow.
munki63
Canada
Ya, I forgot I am getting that too, It seams anything I can bolt on that i come across I have the impulse to buy...Im trying VERY hard to stop because im running out of money LOL
Frosty
New York Crew
Western New York
good deal bro. you will have a very reliable set up with some added power. i run pretty much that set up... you can't go wrong bro... you will be happy with that for sure.
here's my set up - you can add a lot and keep reliability...
Factory Pipe - B-pipe mod chamber
MDS Enhancer
X-Scream exhaust manifold/head pipe bore and port with gasket match
ADA Racing girdled billet head w/33cc domes
62t Cases
61x cylinder - LPW bored, ported and honed
Pro-X pistons - 82mm
64x trued & welded crank
LPW lightened flywheel
Twin 44mm mikuni OEM carbs w/twin fuel pumps
OEM air boxes
Moto tassinari carbon fiber V-Force reeds & cages
Boysen reed stuffers
Riva Yamaha reed spacer plate
R&D intake manifold
XMW waterbox
Jet Works flow control valve
Factory Pipe mod chamber elbow
LPW bored reduction nozzle
Solas Concord impeller repitched to 13/15 w/cut back 3mm from Impros
R&D Aquavien Intake Grate
OEM D-Cut ride plate - new from a 2007 superjet
XMW handle pole bracket
AC aluminum handle pole -6"
AC Racing pole bushings
Invert Technologies turn plate and straight bars
UMI Billet throttle trigger
WDK Diablo hood and nose piece
WDK Composite chin pad
24/7 front foothold
XMW hood hooks
ODI rogue grips
LPW internal fuel filler
XFT 3" monster scupper
WCF footholds
WCF Tubbies
Blowsion Kenney Keepers
E.J. Ratcheting hood strap
Zigg limiting rope
WRX Dave
Freestyle poser
It's all in the tune. You can blow up a stock engine very quickly with a poor tune. Get your A/F mixture right and an engine with those basic mods will serve you well.
2006superjet
just one more part....
costa mesa ca
run synthetic 40 or 35-1 i blew mine up a few months ago had been running it lean with yamalube 50-1 on a high speed run. costs 800+ for new top end. kinda sucks but wear item i guess. mixture both oil gas and tuning is huge.
