reinforcement q's reisn cloth filler
2006superjet
just one more part....
costa mesa ca
i am going to do a hull reinforcment and want to learn all about it before starting the procedure. i dont want to mess anything up or use the wrong stuff. oh ya and i did a search but my questions need specific awnsers.
should i use carbon fiber/ or kevlar/ or glass-how much/where store online
what kind of resin /how much
chapest way to grind ribs. tools
what filler to use on the bondline
what to use to make transition bondline and or handlepole area.foam-nothing
it has a b pipe so i want to make sure it will still fit.
06- doing tubbies prob do them first right
sorry for all the q's
Kennay
Squarenose for the _____
Myrtle Beach, SC
Grinding the ribs is the easiest part by far. I'm going through it now. Use a grinder, and a palm sander, or sand paper and a sanding block. Every rib will be gone in 30 minutes and sanded smooth.
Crab
thanks darin...noswad!
Seattle
:woot:The 435resin, gelcoat, mold release, and surfacing wax are for something else, I also got 30 feet of 2 inch glass tape.
spazzit
the eternal hunt
south jersey
use the West system 404 to fill the bond line....you can do a layer of 12 or 17 oz. biax for rienforce and layer of carb. west system has the resin/hardener/filler for about $120
Ericfox
Do it twice?That's DooDoo
get US composites stuff from their website.... cheaper than west system stuff and will result in the same outcome.... definately get the gallon size, and get the fast hardener if you will be working in colder weather. For filling the bondline I used aerosil/cabosil.... this is what most people use. You can buy everything you need for ALL reinforcing at US Composites... one-stop-shopping --> I like
Mike W
Infidel
North Florida
Some people use 2 part foam to fill the bondline. My last 3 builds however I used 404 filler to fill the bondline. The 45oz size of the 404 filler and 1 gallon of 3:1 epoxy is PLENTY.
