does any one have pictures or a link to a thread of cutting out the tray and refoaming the tray on a 750? Im about to do it an would like to see how other people have done it.
There is a old thread on here: 750sx refoam and footholds http://www.x-h2o.com/index.php?threads/750sx-refoam-and-footholds.127209/
I currently have 2 apart doing the same thing. Word of warning tho, out of all three 750 SXI pro's I have the plate that sits behind the drive shaft bearing was completely rotted away. It was the reason they foam was all wet. I didn't cut mine out as extreme, but a good starting point. Lots of extra glue to remove also.
Good luck.
I originally wanted to keep as much of the hull together as I could, but once you start defoaming you will quickly want more space. Wire wheels are you friend! Many of my seals were also rotted.
