- Texas
I'm going to run a reed spacer but do you re-install the metal backing plate that was there before, the one between the case and manifold? About to hit the parts store and was wondering.
Why do you want to run a spacer?
Mark44
Is it absolutely necessary to fill the crossover in order to run a spacer?
No, but youll still need to run the thin alum OEM block off plate then. That is what the OP is asking.
