Ok guys we got a problem...when I originally took my engine apart and had it rebuilt it was due to a runaway ski because the crank seals had blown and the rear piston seized. So I had the engine bored, honed, rebuilt and I replaced my electronics, flywheel, and stator back to stock. So after getting everything prepped to start (compression 175 in both, mixed gas 30:1, made sure there was fuel in the lines), it started up right away, but then immediately began revving up high just like before I took it apart so I killed it right away. I did not have it on the hose. So what do you think? everything on the ski has been rebuilt except the carbs so Im guessing my problem lies there somewhere?? Its really frustrating how much work I've put in the last 2 months to try to get it running yet the same things happening. Let me know what you think I should do about it. All I want is a reliable ski thats going to run.
Thanks
Anthony
