Blaster rear waterbox in blaster
can anyone advise me or post me a link on setting my blaster up to take rear waterbox.the prefered way is the wave raider waterbox under the battery tray but ive a lightweight waterbox(not sure what make)on the ski when i bought it and fits in fine.
ive already converted to rear exhaust exit left/kill switch side.
is it safe with waterflow etc?
Help would be great as im relatively new to the site and finding it hard to navigate....
tshank123
Yo hablo ingles
Vegas
It depends on what chamber you're running. If you're running a limited, you can cut and flare your U-pipe so it just goes straight back instead of bending towards the stock waterbox. Then just use the stock long hose cut to length. For the rear exit on the right side, I used the stock chamber to waterbox hose. Put the big end on the waterbox exit and fit the smaller end onto a a 90 degree bent tubing. Use a small coupler to attach the the tubing to the rear exit.
If you're running a mod chamber, you have to get creative with tubing bends and such, but you can use the stock long hose to run it back to the waterbox.
Look at post #9 on that link I posted. I explain it all with pictures.
