Hey. I was looking at the standard hole in the steering nozzle for the cable, and I thought if it was closer to the bore it would create a greater range of steering? :thinking:what do you guys think?
Cheers
you can also turn your steering stop the opposite direction from stock. they are kinda rectangular and stock the are set long left to right. loosen it and turn it 90 degrees and it give you about a quarter inch each direction.
I don't like the steering stop turned to the narrow side. I would rather move my cable mount at the turnplate out with a little piece of metal than move the stop. The stop makes the bars turn so far that they get in the way at full lock...just my $.02 And the hole in the steering nozzle is a must. drill it as far in as you can then grind the plastic away to make more room for the throw.
