Up for sale is a ready to run rage composites carbon havoc. It is equipped with the following running gear:
HPE 809cc 5mm stroker with stage 3 case and cylinder porting
Oem sbn44 carbs under prok flame arrestors
Atp flame total loss ignition (includes programming cable and software)
Power factor dry pipe ran dry
Rrp water box
Limited slip 4.7 gallon fuel tank with battery tray
Oem 155mm pump tapped for dual cooling
Skat trak 7/14 impeller
Rrp trim with nozzles
X metal adjustable pole and pole bracket
X metal steering
Straight bars
Thrust finger throttle
This package can be fogged, crated, and shipped to a loading dock in the lower 48 near you for the low price of $11,000 American ($14,000 for lowballers) Plus pp fees if we're not friends/family.
Disclaimer: this hull was purchased cracked and repaired by me with guidance from @Nate_D pics of repair and repair process will be provided to serious buyers.
Selling due to non use, best way to contact me is by text at 563 599 1253 or pm here.
Rrp water box
X metal steering
Straight bars
