i just put a 62t motor from a wave venture in my square nose. rebuilt the carbs and found a 120 jet in one carb and 130 in the other and mine runs fine. your gonna need to fine tune it which takes a while on a trailer. stock exhaust will not fit a 62t cylinder. your gonna need to hone out the bolt holes on the exhaust manifold
This is not a fluke, it is the stock configuration in the couch 760 engines. They also have staggered compression, so don't go thinking your motor needs a rebuild based on compression differences.
The steps for fitting a 760 motor into a SJ are pretty easy.
1. Make the exhaust fit. Use a 61X manifold and a 61X head so that the stock SJ exhaust will bolt up. In order to get the 61X exhaust manifold to bolt to the 760 cylinder, you need to either increase the bolt hole size in the manifold or you need to install time-certs or helicoils into the cylinder exhaust bolt holes. Reason: The 61X setup uses M8x1.25 bolts while the 760 setup uses M10x1.25 bolts. Fix it at either the manifold or the cylinder.
You might think about port-matching the exhaust manifold to the cylinder, as the cylinder ports will be a bit taller than the 61X manifold ports. You will also need to either cut a 61X exhaust manifold gasket to fit properly or use a 62T manifold.
2. Use the right electrics. There isn't anything wrong with using the 760 stator, flywheel, CDI - but you cannot mix and match 61X stator/flywheel/CDI with the 760 stator/flywheel/CDI.
3. Disable the oil pump. This is done by simply installing a 701 flywheel bolt and flywheel cover (without oil pump and blocked off)
4. Either leave the carb jetting the way it is or bring both mains to a 125.
