question about my square
h2odesperado
Pin it to win it
Charlotte, NC
i found a pic of my square from when i had the moulding off to turf the rails. my garage is nasty, but you can see the rivets. They're the white bumps every 6 inches or so.
thegoldenboy
RN Surgery... soon
Toronto
:rolleyes: No...stock molding is held in with bolts and nuts.
And... I'm not sure where bolts and nuts fit into the question?......
Fill in the old holes in order to have a smooth surface to adhese the Blowsion trim piece or Hydroturf to. Leaving the holes will allow water to push the turf or trim off the rail, and allow water to creep in behind your adhesive/glue.
h2odesperado
Pin it to win it
Charlotte, NC
if you look at my pic it alternates between a hole where a screw that held on the rail and screwed into an acorn nut was, and there are rivets as well. They stuck out about a 1/4 inch on the underside of the rail, and I'd know because I've grabbed my bond rail to stop my ski from flying away from me and did a number on my fingertips cuz of those stinkin rivets.
W
wydopen
Guest
i think im just gonna leave the rivits and order some hydroturf rails
