air blair
you are the reason
- thumb, mich again
Anybody have pump tunnel pictures that accommodate them big pumps?
Sent from my SPH-D710 using Tapatalk
Superfreak Circus only take 155
	Are you sure about the rok r matt? I know jeff (WDK) has one in his. But I'm not sure if it just "bolted right in". I know the op is just talking about pump tunnel. Dose a 155 mm just "bolt in a chan"? Not meaning to thread jack
	yeah I am sure about the ROK-R.
The bolt pattern for 144 and 155 pumps is the same. But the diameter of the pump body is obviously different. This is what bolt-in vs non-bolt-in comes down to. Also, the pump shoe for the 155 is a bit larger.
There is probably more to making a 155 and larger work than just making the pump shoe fit. The intake tunnel must feed the larger pump, too.
But are you sure sure?[/Q
Yeah its just a easy "bolt in" burton. Oh wait you have not done it either.!
I know the bolt pattern is the same matt. But what im asking is what other modifications have to be done if any? Besides the pump shoe. Dose the hull need to be grinded? Dose the plate have to be changed?yeah I am sure about the ROK-R.
Matt is sure and I had his 155 bolted into my hull with no modifications needed.
