What sealant or adhesive do you guys use when putting the pump shoe on?
			100% silicone adhesive (clear) for me. I'm not a fan of 5200 for a whole bunch of reasons. 5200 as an adhesive to me is like wrestling shoes as a riding shoe is to me. Over hyped and wrong for the application.
Back in the old days the pump shoe was also part of the pump, not seperate like they are now. With Silicone, the shoe (SJ Type)Old skool RTV silicone,if you ever need to remove the shoe for any reason.Dam,you guys are brutal with some of the sealants you use.Just go buy a chisel and sawzall for later removal
Silicone was used for 20 plus years without issues when properly applied.What happened!?
It's polyurethane based so its acclaimed 'flexibility' deteriorates over time especially if exposed to UV. It's not viscous enough, so it runs like a MF'er and makes a mess. It's adhesion qualities and vibration resistance is over rated. I've had 3 bilge pumps come free from my hull using 5200 to bond them down. I've never lost one in 15 years using 2 part marine epoxy. Plus if you ever have to remove it, good luck, unless you have some DeBond and a weekend to kill.I'm interested in the reasons you don't like 5200.
“Technically” anything can happen,but for the most part l haven’t had any issues with rtv.And don’t say cause l don’t keep a ski long enoughBack in the old days the pump shoe was also part of the pump, not seperate like they are now. With Silicone, the shoe (SJ Type)
technically could move some when the pump is installed. Or intake grate putting pressure on it pulling it down and lose......
