First you will need to remove the driveshaft. It presses out of the back side or the stator section once the pump cone is removed. Once the shaft is out you can pry the seals out of the front and press the other bearing out the back if it staying in the stator.
Use something to pry upward going in and under the center of the seal. I use a foot long flat head that i cupped the end of just for pulling seal. Just be careful not to go to far under the seal as you will gouge the outer metal area.
You can buy a seal puller at any local auto store too.
